1978 - 1996 Big Bronco
Suspension Help
Old Oct 3, 2004 | 12:56 PM
fishin machine's Avatar
fishin machine
Suspension Help
Guys I need help, I think I broke somethin. Whenever I hit a pot hole I can hear/feel that somethings broke loose, and whenever I make a tight turn I can feel a pop in the front end. I originally thought maybe I broke a ball Joint then a tie rod, now I'm at a loss. You guys got any suggestions?
Thanks
Abel
Old Oct 3, 2004 | 01:13 PM
WhëëlMå1's Avatar
WhëëlMå1
Check your radius arm bushings. One probably gave out, and now the radius arm is moving around under suspension movement.
Old Oct 3, 2004 | 01:16 PM
fishin machine
I replaced those last year w/ poly bushings. But thanks I'l check them now.
Old Oct 3, 2004 | 09:19 PM
dcotton's Avatar
dcotton
Also check your stabilizer bushings and connect rods, if bad or missing they will make noise.
D
Old Oct 3, 2004 | 10:24 PM
greystreak92's Avatar
greystreak92
Axle pivot bushings may be to blame as well. Check everything under there. Something will rear its ugly head at you.
