Transmission Slipping??
Old Oct 3, 2004 | 09:23 AM
Cobra R's Avatar
Cobra R
Question Transmission Slipping??
I have a 2000 F150 4x4 4.6 with automatic (base XL model). The problem is that when I stop and take off again it feels as if my tranny is slipping. When you press the gas pedal it hesitates for a second then catches and starts moving. It feels as if it is a broken tooth on the ring gear but it only happens in a stop and go situation. I thought the tranny fluid or filter could be bad so I had it changed. No luck, the problem is still there. I don't have any where to pull the diff cover to verify if it is a tooth missing on the ring gear. Does any one know of an easy way to check if a tooth is missing other than pulling the cover or if it could be something else?
