measuring alternator current; rebuild
Old Oct 3, 2004 | 06:06 AM
aurgathor's Avatar
aurgathor
I think my alternator isn't working very well because if I have my headlights and rear defroster ON while the engine is at idle, I can see a noticable voltage drop; furthermore, last night I checked my battery and it was showing only 12.2V, and I was charging it for over 15 minutes in a 10A setting until it was showing a more reasonable 12.5V.
So, questions:
a) what is the best way to measure the amount of current my alternator is capable of supplying?
b) what's normally going bad? the brushes?
c) how difficult is to rebuild an alternator?
Car is a '95 Bronco, BTW.
Old Oct 3, 2004 | 06:47 AM
Bob Ayers's Avatar
Bob Ayers
The way most alternator testers work, a load current is applied across the battery until a drop in voltage is seen, and this is the output current of the alternator. Make sure the battery is fully charged when this is done.
Old Oct 3, 2004 | 09:15 AM
65CJ5's Avatar
65CJ5
Check the voltage at the battery with a meter. When it's not running, 12+ volts is OK. Check again when you start it up and it should read 14+ volts. If it's much lower or higher than that check the alternator and regulator.
Old Oct 3, 2004 | 01:08 PM
Franklin2's Avatar
Franklin2
I would get a voltmeter and check the battery voltage with the truck running, but no current draw, and then turn on your headlights and defroster, and measure the voltage again. With the current draw, also rev the engine a little bit and see if the voltage rises. The measurements can give clues to how bad the situation is. You could also take it to a car parts store that has a testing machine.
