Tail light short
Old Oct 2, 2004 | 10:16 PM
Freighttrain's Avatar
Freighttrain
Angry Tail light short
My 87 F150 4x4 has a short somewhere in the tail light wiring.The lights will stick now and again and the switch on the brake pedal along with the wires get real hot(ok,shot is after the switch somewhere).I was wondering if there is any spacific places the wires could or normally get rubbed or pinched on this truck to narrow down a search before I go tearing looms open to check the wires.The funny thing is that even after the lights are out that some times they will come back on by them selves so I think the switch has gone bad also(heat damage-suck blistered my finger tonight).I need to find the problem before it burns to the ground.
Old Oct 3, 2004 | 10:36 AM
broken wire's Avatar
broken wire
I saw this on a '79 F350 the other day, melted wiring to the brake switch and flashers, replaced flashers, brake switch and had to do the melted wiring also. Sounds like your brake pedal switch is shorting out to me. Broken Wire
