Sponsored by: Real Truck
fog lights
Old Oct 2, 2004 | 04:04 PM
ehchvac's Avatar
ehchvac
fog lights
can I use the factory fog light wires to run a set of 85 watt piaa fog lights .
or will it be too much for the factory setup.
I dont know what the factory fog lights wattage is .
thanks
Old Oct 2, 2004 | 04:21 PM
HeavyAssault's Avatar
HeavyAssault
If you want the factory lights to power the PIAA lights at the same time as the OEM lights, I'd suggest using a relay. You can connect the relay to the power wire on the OEM to trigger the power to the PIAAs. Your PIAA lights should have a complete wiring setup including the relay, use their wiring and use the relay to trigger the power off the OEM harness.
Old Oct 2, 2004 | 04:33 PM
ehchvac's Avatar
ehchvac
I have a 2004 350 and have replaced the factory bumper and fog lights.
I want to use the factory head lights and the piaa replacement fog lights like I used the factory original setup .
I am not trying to use the new lights with the old fog lights.
Old Oct 2, 2004 | 06:25 PM
wlihntr's Avatar
wlihntr
i replaced the stock bulbs in the factory fogs with 65 watters and its been fine for a couple years.
Old Oct 3, 2004 | 05:16 AM
HeavyAssault
I would say it will work fine to use the OEM wiring to run the lights. You may consider running a thicker gage wire to prevent damage due to current draw. If I remember correctly the OEM fogs are a 55 watt bulb.
Old Oct 3, 2004 | 05:32 AM
Bordaine's Avatar
Bordaine
I put PIAA super whites in my fog lights, If I remember correctly they where 65W (almost 2 years ago) and I have had no problems.
Old Oct 3, 2004 | 09:15 AM
ultraclassic's Avatar
ultraclassic
Higher wattage bulbs
Slightly off subject.
But do the stock fog lights use H3 bulbs
If so I have seen some from Piaa and Sylviana and Hella that are higher wattage
65 up to around 130 instead of the standard 55 W
Would a higher wattage bulb be too much of a drain on the system.
I do have the dual batteries
Here are some sights that sell them
http://www.rallylights.com/hella/H3.asp
http://shop.store.yahoo.com/rodi/xxxpiah3.html
http://www.4by4connection.com/h3bulbs.html
I would think that the higher wattage bulbs would be a cheap alternitive to replacing or adding to the existing fog lamps but can the stock fog lights handle them
Any thoughts????
Old Oct 3, 2004 | 02:44 PM
wlihntr's Avatar
wlihntr
Any thoughts????
the stock bulbs can be replaced with 9005's(the factory replacement is an 899)
