Sponsored by: Auxito
Engine Shuts Down on Start Up!
Old Oct 2, 2004 | 12:28 AM
VadPhoenix01's Avatar
VadPhoenix01
Unhappy Engine Shuts Down on Start Up!
Hi,
I am having a problem with my 2000 F-250. Usually after it sits for about two hours or overnight the engine will startup than just shut down, and it will continue to do this until you can hold down on the gas pedal and brake and take-off. But, after running the truck for about 30 mins. it will work fine. Also, I noticed that when it stops the rmps will gradually (quickly) drop below the 500 rpm mark and the engine will shut off.
My father thinks it may be the Catylitic Converter, but the Check Engine light has not stayed on yet, but I need to find out what is wrong because I cannot afford any down time soon.
Thanks for any information.
2000 F-250 Crew Cab
5.4L V8
122,000 Miles
STOCK, NO MODS
Old Oct 2, 2004 | 10:47 AM
SiNNeR's Avatar
SiNNeR
i have a similar problem with my 2000 F150 w/ 5.4
hope someone has an answer here soon.....
Old Oct 2, 2004 | 02:58 PM
gfreek's Avatar
gfreek
Its prob the IAC, Idle air control valve. It controls air bypass, I believe, at idle. My 99 5.4 has been doing the same thing intermittently, so I am just going to replace it. You can test with a multimeter, and the process is stated in other IAC postings and its in the Haynes repair manaul
Old Oct 2, 2004 | 03:02 PM
Gary B's Avatar
Gary B
replace the IAC. that will fix it!!
Old Oct 2, 2004 | 08:30 PM
VadPhoenix01
Hey, I took that advice you gave me and will be installing the new IAC tomorrow and will let you know how it turns out. Sorry about posting to the wrong fourm thread.
Old Oct 4, 2004 | 10:40 AM
Fordfanz's Avatar
Fordfanz
so hey did it work I was wondering cause I have a similar proplem
l
thanks for the info
Old Oct 4, 2004 | 03:15 PM
RoyalFord's Avatar
RoyalFord
Please read the FAQ's at the top of the 97-2003 F-150 Page, it is there for common things like the IAC.
Yes, your problem is most likley the IAC.
Search for IAC - Idle Air Control Valve
Bryan
Old Oct 9, 2004 | 03:23 AM
VadPhoenix01
Talking It works!!!!!!!!!
Hey, sorry it took sooooo long to get back to the fourms. It worked perfectly. No probs since changing it out.
Thanks alot to everyone who responded to my request.
