Electric Exhaust Cutout
Old Oct 1, 2004 | 08:11 PM
1993-F150's Avatar
1993-F150
My Bassani exhaust has rusted out from the Y pipe back. I am looking at different alternatives one is a Electric Exhaust Cutout. Has anyone used one before. Here are some links to what I am talking about: http://www.quicktimeperformance.com/QTEC/index.html
http://www.streetpro.us/Products.html
http://www.buickgn.com/electricexhaustcutout.htm
http://www.mccordcg.com/mpp/mpp.htm
Thanks in advance for any help!!!
Old Oct 1, 2004 | 09:36 PM
ehchvac's Avatar
ehchvac
http://www.dmhperformance.com/
these are the ones I have on my 55 chevy
what do you need to know ?
Old Oct 7, 2004 | 02:47 PM
Redbob's Avatar
Redbob
Those are pretty slick; my previous employer made an exhaust system standard on the Nissan Skyline (a twin-turbo Japan-only model) that used a valve like the "streetpro" unit, that was electronically controlled to open only above a certain rpm, and which bypassed a portion of the muffler.
We then developed a system for the C4 LT-5 (ZR-1) Corvette using the same type valves, to "short-circuit" the dual mufflers above about 4000 rpm. It worked wonderfully well, and as long as it didn't open at idle or low rpm, it still sounded good, wasn't excessively noisy.
Needless to say, GM didn't want to do it on the Corvette because it "cost too much."
(We would have charged an additional $50 a car to incorporate that feature, plus maybe another $35 for the electronic control module).
So I'd say, go for it! But I'd recommend (a) using the streetpro unit, so the operating module is isolated from exhaust heat, and (b) installing an outlet pipe from the bypass running to the rear of your truck, to avoid the really obnoxious noises you get with too short exhaust pipes.
- R
Old Oct 7, 2004 | 02:53 PM
1993-F150's Avatar
1993-F150
I have always wondered about the durability. I live not too far outside Chicago and I would hope the units could last a season or two with our winters and salt.
Old Oct 7, 2004 | 03:49 PM
Redbob's Avatar
Redbob
That might be a problem; what do the suppliers say? Will they give a warranty against corrosion?
If not...
Old Oct 7, 2004 | 03:56 PM
1993-F150's Avatar
1993-F150
Some give one year. But winter is like 6 mos. here. I will keep everyone informed after I make a choice of manufacturer.
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
CheeksMcDuke
Mar 1, 2010 02:31 PM
Deebo54
Jan 21, 2006 08:29 PM
gtex
20
Jul 14, 2004 06:04 PM
