vacum lines???
Old Oct 1, 2004 | 10:22 AM
88blkranger's Avatar
88blkranger
vacum lines???
88 ranger with an 85 2.3L (carbed). I went through and worte down emission part numbers and called the dealer. I am trying to go through the vac lines and figure out if they are hooked up where they are supposed to be. The reason for this is that i found this valve like thing that has 3 ports 1 for dist, 1 for manifold, and 1 for carb. when i pulled the lines to check for vacum there was none. Plus the plastic line snapped off. Does anyone have a vacum schematic that they could e-mail me??
Old Oct 1, 2004 | 05:52 PM
el conquistador's Avatar
el conquistador
there should be a diagram under the hood near the hood prop
