Bronco II Ford Bronco II
4x4 lights don't work
Old Jan 22, 2002 | 06:21 PM
tcbradbury98's Avatar
tcbradbury98
i just put a newer tranfer case in my 87 bii 5 speed, it uses the elect. BW 1350, everything went fine but now my lights don't light up on the buttons on the ceiling, what's wrong? where are the fuses for the 4x4 system? need help fast, thanks in advance
Old Jan 23, 2002 | 12:19 AM
babybroncoii's Avatar
babybroncoii
they should be in the bottom left panel under the steering column. and if i remember correctly the panel shows about 3 fuses that are all linked to the 4x4. every once in a while i need to pull a fuse out and put it back in to reset the 4x4 to get it to light up and actually switch in to 4 wheel drive. there is probably something wrong with mine but i don't use it often enough and it works when i need it to. good luck
Old Jan 23, 2002 | 03:40 PM
tcbradbury98
ok i know the shift motor works, and the trans. case can be manually shifted to four high or low by turning the shift **** that the motor turns, and the driveshaft won't turn in four and will turn in in two high. when i press the buttons, the relay clicks, but the lights don't light up, about three to five seconds later the relay clicks again, i'm assuming that it is unable to find four wheel drive and the relays click back to two wheel drive. is there some sensor that might not be functioning? i know that my neutral safety switch is probably not functioning, and i think that this is probably why i used to be unable to shift into four low. but would that affect four high? or could it be a combination of the two? also, all the fuses are good and have current. HELP, I NEED THIS TRUCK TOMORROW!
Old Jan 23, 2002 | 05:38 PM
steve_'s Avatar
steve_
4x4greenbeast
17
May 22, 2014 12:10 PM
Mussifto
Dec 21, 2012 06:41 PM
danskool
25
Jul 26, 2012 02:33 PM
Explorer Freak
Oct 2, 2011 10:57 PM
nixvet2000
1978 - 1996 Big Bronco
May 20, 2011 12:31 AM
