1978 - 1996 Big Bronco
Need Help Horn not working when engine is running
Old Sep 30, 2004 | 08:52 PM
tygarcia's Avatar
tygarcia
Exclamation Need Help Horn not working when engine is running
The horn is not working when the engine is running; but when engine is turned off it works. What do i do?
Old Sep 30, 2004 | 09:00 PM
Trublufords's Avatar
Trublufords
What you need to do first IS tell us what year Bronco you have(tilt...etc)
Old Sep 30, 2004 | 09:02 PM
tygarcia's Avatar
tygarcia
82 ford bronco; no tilt, the horn works when engine is not runningn so its getting fire when pushing the horn.
Old Sep 30, 2004 | 09:24 PM
Trublufords
Find horn fuse, should be powered all the time- with test light touching end of fuse(should be lit) start engine and see if it stays powered.Fuse box is powered 2 ways-fuse link straight from post on starter solenoid to one section of box and through ign. switch to other section of bonot ness. sections of box but certain fuses need to be powered only with key on- radio.etc.).Did this just happen? What was last thing done to it? did it work before that? Did you just get this?22 years old- had any rewiring?(rigging)
Old Sep 30, 2004 | 09:42 PM
tygarcia's Avatar
tygarcia
I have had for 2 years and have done a lot of work to it but no rewiring. Did not notice till the other day when I went to go get my inspection sticker and it did not blow. When I got home to see what the promblem was it worked and notice it worked only when the engine was off. Now if the fuse is not working when the key is off how do I fix? Did not check that!
Old Oct 1, 2004 | 09:02 PM
Cheggie's Avatar
Cheggie
You need one of those bumper stickers - "Horn broken, watch for finger!"
Old Oct 2, 2004 | 09:41 AM
Trublufords
Great idea Cheggie- was down in SC not long ago -seems finger is real popular.TY one thing at a time -check first and will try to help with results of testing.
