a little help please
Old Sep 30, 2004 | 06:27 PM
tirion's Avatar
tirion
Thumbs down a little help please
I just bought '85 F150XL 4x4/302/manual transmission. 29k miles on odo, but who knows. Engine was rebuilt, so was tranny and transfer case. The electrics seem sound. Truck runs like a champ when it's cold and rainy. The uglier the weather, the better it likes it. BUT!!!! It skips and stutters like a brahma bull when it's warm and dry. Changed all fuel filters, replaced both fuel pumps (2 tanks), nipped the ends and re-attached vacuum lines, replaced coil. acts and feels like fuel starvation, but...?
Old Sep 30, 2004 | 09:56 PM
locknkey's Avatar
locknkey
Just an idea, but if the temp is warm an muggy, then the fuel tank could be stopped up, causing the tank to pull a vaccum, thus creating a vapor lock situation, when its cold, there isn't any vapor lock, suggestion...check the fuel tank charcoal canister for wrong vaccum connections, or the line could be crimped somplace...
Old Oct 1, 2004 | 12:08 AM
big hoss 29's Avatar
big hoss 29
It sounds to me like your fuel pump is maybe getting too hot. I had that happen to an 83 F-150 I had. My Dad suggested I change it out, and bingo, it worked. Sounds crazy, but it worked.
Old Oct 1, 2004 | 09:47 AM
topgo's Avatar
topgo
Smile Vapor Separator
It is 6" from the carborator. When fuel is cool it is more dense. This thing is often overlooked cost $42.00 from FORD. I don't know any way to test it.
I have been all thru this with a 1985 F350/360. Installed everything new than went back and exchanged the new with the old parts over 30 days time till I found the bad part, The Vapor separator. Good Luck Larry
Old Oct 2, 2004 | 11:34 AM
tirion's Avatar
tirion
Smile a little help
haven't looked yet, but saturday is my day to do that 8-) didn't know there was such a thing as a >vapor seperator< willok for it and check it out. for $42 how wrong can i go.
engine is efi 302, so maybe not, but thanks for the direction.
john
Old Oct 2, 2004 | 11:41 AM
tirion's Avatar
tirion
thanks for the tips
pulled lines from charcoal cannister and the skip went away, away, away 8-)
gracias, thanks, danke, etc.
