Sponsored by: Kumho
Steering loose?
Old Nov 1, 2004 | 09:28 AM
  #46
gatesj's Avatar
gatesj
You'll have some rubbery give to it but no actual freeplay. The rubbery give that ruins the precision is just a truck thing, it's a rubber joint in the steering column to isolate vibration.
Old Nov 1, 2004 | 08:31 PM
  #47
Marquis's Avatar
Marquis
Loose steering
I have a 91 full size Bronco with the same problem, 93K miles. The steering wheel moves about 2 inches before the truck reacts when going straight on the highway. Every little change in the road moves the truck causing it to swerve which is very unnerving and you must pay attention. I have adjusted the screw on the steering box but it tightents up the steering without really fixing the problem. If you make it too tight you can crush the little needle bearing inside the box. Some posters claim they turned the screw two or three turns which doesn't seem possible as the screw will usually bottom out within one half to three quarters of a turn. I also was thinking about replacing the box but it sounds like that won't fix the problem. My 86 Bronco didn't have this problem.
The steering sucks.
Old Nov 2, 2004 | 01:10 PM
  #48
PrPlayboy's Avatar
PrPlayboy
There are alot of ball joints to look at. You have inner and outer tierod ends, Pitman arm, Idler arm, etc..
Old Nov 2, 2004 | 06:28 PM
  #49
gatesj's Avatar
gatesj
The steering sucks.
If it makes the steering feel tight without fixing the freeplay the problem is obviously somewhere else.
Keep in mind the rubbery feeling ragjoint, it will not handle like a little sportscar. There is a difference between the rubbery but still connected feeling and a loose freeplay feeling.
Old Nov 2, 2004 | 09:31 PM
  #50
midlf's Avatar
midlf
adjustment proceedure
The steering box adjustment proceedure in the Haynes manual has 23 steps and requires the steering wheel cover to be removed and to drop the pitman arm. After reading the proceedure it seems concerned mainly with getting the box within spec for torque. Read a manual and decide if you want to cheat the process with the method suggested in this thread. (I would)
Don't have a manual? You're flying blind without instruments. At least get one of the <$20 ones. I think Haynes is better than Chilton, I have both. Factory Manuals from www.helminc.com are more $$ but also more complete and specific to your year.
Old Nov 2, 2004 | 09:37 PM
  #51
midlf's Avatar
midlf
Oops
I just found page 2 of this thread and see Gatesj has covered my point already. Advice on manuals still holds.
Old Nov 11, 2004 | 12:14 AM
  #52
edrush59's Avatar
edrush59
Originally Posted by gatesj
You'll ruin the box in short order if you adjust it that tight.
I know. I only drove it a couple miles before loosening it. But you never know if you have it tight enough until you get it a touch too tight.
I realize this thing ain't a sports car, but it handles worse than any vehicle I have ever driven with the exception one very old Ford work truck that had about 90 degrees of slop in the steering box.
I just read a post that frozen u-joints can cause similar behavior. I suppose the u-joints have to move a bit when the tires turn (in 2WD), but this seems like a stretch.
Old Nov 12, 2004 | 09:17 AM
  #53
gatesj's Avatar
gatesj
U-joints would cause it to turn hard, not be sloppy, but I think that's what you mean anyway.
Old Nov 15, 2004 | 04:56 PM
  #54
93XR7's Avatar
93XR7
I just got my first Ford pickup, a 95 F-150 XLT Extended Cab 2WD 5.0L truck. I also was uncomfortable with the steering on the truck. Is this problem systematic with all the Ford trucks? I have no qualms rebuilding the entire front end if it needs it. But, if it's the steering box, I'd rather be able to identify that before I sink $750 in rebuilding the whole front end. The truck has 144,000 miles on it by the way.
Old Nov 15, 2004 | 05:02 PM
  #55
dynamicdesigns's Avatar
dynamicdesigns
My new '04 F350 with less than 8K miles on it was squirelly from the start,,,my old '02 F150 with 18K thru 40K same thing. I've been told by many that the steering box needs a bit of tweaking,,,,but after reading some of the other info that others have posted here, I'm wondering if I should take a chance adjusting the box. I was going to do it a while ago, but I've been put off by fear of damaging something.
Whatever you decide to do,,,post it and let us know how it goes.
Thanks,
Mark
Old Nov 16, 2004 | 09:02 AM
  #56
gatesj's Avatar
gatesj
As long as you don't adjust it so tight it binds you're OK.
Old Dec 1, 2004 | 12:16 AM
  #57
JimTZ's Avatar
JimTZ
Originally Posted by edrush59
I have the same problem with my 94 F150 SB Reg Cab 4x4. It drives me nuts! I have tightened the steering box screw until it doesn't want to return to center. That makes it more difficult to drive. I have never been able to find an obvious cause. It drives very poorly in wind or on an uneven road surface. Or if the road suddently tilts or if I hit a bump. On a good road with no wind it usually drives just fine, but under certian conditions it seems downright dangerous. I have thought about replacing the steering box but I am afraid I would still be in the same boat after replacement. The steering wheel will move 1-2 inches before the steering reacts, but when I look out the drivers window the front tires seem to follow the steering wheel closely. I suppose a rubber mounted front end is never going to be real accurate, but I really hate the way this truck drives.
I have the exact same truck (except extended cab) with the exact same symptoms. Joints are all tight. I tried adjusting the steering box (didn't follow the factory procedure), got it just a bit too tight and RUINED THE BOX. Full of metal shavings when opened it up. Had to buy a new box, but it only slightly improved the steering play! Now I've got 60K miles on the new box and the sterring play is worse than ever. I have to correct when any size car passes me on the freeway. It was just realigned and (they claim) suspension joints all checked by alignment shop... zero improvement.
I sure don't recall it being this bad when my truck was new in 94.
Old Dec 1, 2004 | 11:25 AM
  #58
MSM0075's Avatar
MSM0075
wow. thats intresting. keep us updated..
Old Dec 2, 2004 | 06:37 PM
  #59
rangerang's Avatar
rangerang
Trailering
Originally Posted by PrPlayboy
I found the screw! It's as stated right on top of the steering box. It is in fact a stud looking like screw with a nut on the bottom. The top of the stud has a slot for a flat head screw driver the the bottom nut keeping it tight was a 16mm nut. I loosened the nut and turned the screw clockwise about one complete turn then retightened the nut while holding the screw in place with the screw driver and it's a night and day differance! I think i will give it 1/2 a turn more today. I'm sure you can over do it so becareful. I will see about taking a pic later on today.
If you get it too tight, the steering won't return to center and you'll have to
manually return it. You'll look like a drunk going down the road. As I recall,
the method in the manual has you tighten or loosen the screw until the torque required to turn the steering wheel is in a certain range and required a special tool to measure. I believe over-tightening will also
damage the steering gear eventually.
I had a very loose '90 Ranger that improved somewhat with tightening
but I eventually replaced the power steering gear. It's now much better
but still has that bit of looseness that the others describe.
Old Dec 6, 2004 | 04:44 PM
  #60
gatesj's Avatar
gatesj
I wonder if the rag joint gets crappy on these trucks. My '91 4x2 actually feels pretty good considering it has ball joints that are loose as a goose (I do NOT drive this on the road anymore, endangering others' lives). My '95 4x4 feels heavier and I think the rag joint flexes more. There is no actual freeplay but there is a certain amount of effort to keep it centered in its lane with a wind along with movement of the steering wheel, especially after I get used to driving the little cars. It feels rubbery.
