Went down to the Ford dealer and bought an 04 F250 Crew Cab 4x4 xlt. I could not pass up the good deals any longer. What a difference between my V-10 Excursion. I should have gone with the diesel to begin with.
The only negative thing is when I got in it this morning and turned the air on it will only blow out of the defrost. No other settings work. I am not to happy about this. I hope it is not a sign of things to come!
I know it's not the right answer but, give your defrost/a/c controls time to break in. Mine did the same thing for about a week. Leave it on for a while and it "should" switch from defrost to a/c.
I see you have not been properly............WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum. Enjoy FTE
I don't think you should worry too much about a simple motorized damper for the HVAC unit. It could be as simple as a blown or missing fuse. Otherwise, they just have to switch out the motor. I would strongly advise, however, that you begin to keep complete records of all items you have done to the truck (service records, mods, etc.).
Welcome to the forum. I had the same problem a few weeks ago. After a few days it became intermitant(sp). The dealer had it fixed in one day; it was a bad vaccuum pump; fairly common problem,easy fix. Other than that the truck runs great. Enjoy!
Congrats on the new rig- Mine had the same symptom which turned out to be a loose control ****. It took the dealer a whopping 20 minutes to fix- Mostly in processing the vehicle in & out. 39,012 miles and thrilled with the 6.0
Thanks for all the replies. I took a look at it and it turned out to be a blown fuse. At the Ford Dealer they have a security feature that will not allow the truck to crank. When the man was disabling it in the fuse panel I think he must of done something to make it blow.
Any ways, got 110 miles on the new 6.0 and like todder says, I cant keep the kool-aid smile off my face!
