Pushrod Guide plate Necessity
I'm building a 460 and need to know if I should use guide plates for the pushrods. I am planning on using a set of roller rockers. I'm using '68 heads off of a 429, so I already have studs for the roller rockers. I was just curious because I have never dealt with guide plates and need to know whether to use them or not. I heard somewhere that you have to mill down the boss that the studs screw into the thickness of the plates. Do you still have to do this if you are going to use adjustable roller rockers? Thanks for the input.
on
If you want to use stud mounted rollers you will need guide plates that are held in place by the screw in studs. So yes you will need studs and guide plates. I don't know if you have to mill any thing down on a head with pressed in studs, but at the very least you will have to drill and thread the holes. The guide plate is the only thing that stops the rocker arm from spinning on the stud so if you don't have the guide plates you rocker will just slip right off the valve.
-Johnboy
-Johnboy
