Aftermarket Products
Sponsored by: Worksport
automatic window slipping.
Old Sep 30, 2004 | 12:04 AM
scottmccoon's Avatar
scottmccoon
Unhappy automatic window slipping.
My passenger window has auto windows and I hear the motor run but it won't push the window up. any ideas?
Old Sep 30, 2004 | 01:00 AM
MatthewC's Avatar
MatthewC
Having installed a couple of window motors before I have a thought. Im thinking that the bolts holding the motor against the cogs that raise the window have backed off, so the wheel of the motor isnt connecting. Best course of action is to pop off the door trim and take a look at whats going on. See what you can see, the post again.
-Matt
Old Oct 1, 2004 | 10:54 PM
scottmccoon
thanks for the reply, I popped off the cover but I couldn't feel anything loose it is hard to evaluate because of the metal plate in front of the motor. is there a way to get around that or take it off?
Old Oct 3, 2004 | 10:46 AM
MatthewC's Avatar
MatthewC
Not really. Youve gotta contort your head to look in to see what the gears are doing. If you end up having to remove the motor, you will have to drill out the rivets, then use bolts when you reinstall it. It is a real pain in the ****. Without seeing your situation I couldnt really give you an accurate answer for you. Good luck, man.
-Matt
Old Oct 3, 2004 | 10:51 PM
Torque1st's Avatar
Torque1st
Posting Legend
What vehicle do you have?
