I installed a air intake and I get about 40 miles per tank more so that was a plus. I have been reading some things about a Electronic Engine Ionizer Fuel Saver and some Tornado Fuel Saver are these things just a load of crap or what or do they really work?
I've heard it doesn't help you much more, if any at all...because the air is just as "cold" as it would be with a regular intake.
Another tip-new wires/plugs
drive as if you have an egg between your foot and the gas pedal--proven to be affective but impossible for most people not to mention any names but initials are me and joe
most of the time I drive normal but sometimes i like to get on it and hear my flows rumble. I was thinkin about getting the Electronic Engine Ionizer Fuel Saver because if you are not happy with it they give you your money back in full. I dont know if it is a waste of time or not.
http://store.yahoo.com/engineionizer-store/ is where you can read about it or buy it. All I did is go up to the thread search and typed in improve gas milage and it brought some items up like this and some improve fuel economy tornado thing. Check it out and tell me what you think.
Electronic Engine Ionizer Fuel Saver sounds like Asian placebo aphrodisiac.
Time-honored methods of good state of tune, compression increase, ignition timing tweaking, thoughtful cam selection, friction fighting, decreasing wind resistance, rolling resistance, and vehicle mass, freeing up the exhaust, overdrive gearing, and lightening the throttle foot will always get you farther than some hypester's sinecure of gimmickry. I bet increasing the tire pressure and using quality synthetic lubes in the engine, gearbox, and rearend is likely to give you better results than some overblown "miracle" gadget.
tornado, is junk, does not work. i installed a mac cold air intake and got 2.5 mpg. i heard delta 40 series flowmastes will help with a better flow, and synthetic oils and lubes will help as well. tire pressure is a big thing as well as alignment. running factory size tires it a thing to look at as well.
thanks i thought that it was a load. I guess i will just a hve to deal with it. The bigger tires decreased my mpg by 2 or som miles but nothing dramatic.
