I have an 86 BII with 2.9
I rebuilt the engine two years ago. I also drive another truck, so I have probably put on 5,000 miles.
Somehow I got a piece of metal into the #5 cylinder. I took the head off and the piston is cracked.
All I can think of, is there was a washer I dropped when I was putting the engine back together. I hope it did not come from anywhere else.
Has anyone heard of pieces of steel in a cylinder?
If nothing else, you can have a great weekend, knowing you are not re-re-building an engine.
:-X11
I have seen pistons cracked by valves that have dropped after the valve keepers let go. Also seen parts of a spark plug imbedded in the piston that was destroyed by severe detonation. Besides destoying the piston the cylinder wall was scored & the rod bent. You are probably right on what happened.
>happened.
I've seen bad casting in the cylinder walls or airpockets inthe
casting let go and get popped out into the combustion chambers
makes for a real mess!
Rich
Ford Trucks Built Tough!
not with rocks
Watch out "X" Mayor of Truckville
