Sponsored by: Auxito
engine noise cant find probelm
Old Sep 28, 2004 | 08:10 PM
meh129's Avatar
meh129
Question engine noise cant find probelm
I have a 99 f150 with a V6. I am getting a knocking noise when I put it in gear but the noise greatly reduces in sound when I put in park or neutral. I removed the belt and I get no noise at all. All the pulleys and tensioners seem to be OK.
Does anyone have an idea what could be causing it. Thanks MEH
Old Sep 29, 2004 | 12:01 AM
Racerguy's Avatar
Racerguy
Hi Mike and welcome
How many miles on your engine?
Sometimes if the main bearings are worn the belt will pull up on the crankshaft and cause a knock.
Since the noise changes in park and neutral it's also possible that you have a worn thrust bearing on the crankshaft. In gear there is extra force pushing the crankshaft ahead and if the thrust bearing is bad it can cause a knock. You can test for this by prying the crankshaft back and forth by the balancer on the front of it. There should be between .004-0.008" of end play.
Let us know what you find.
Old Sep 29, 2004 | 08:14 PM
meh129's Avatar
meh129
Thanks for the input, the truck has just under 100,000 miles. I will say that the knocking noise is really loud when in gear.
