Sponsored by: Kumho
steering stablizers on TTB
Old Sep 28, 2004 | 02:42 PM
s1120's Avatar
s1120
Does anyone have a picture of an installed steering stablizer on a TTB ford? I have an 95 Bronco, and I am installing one, and have to fab up some brackets. Any tips for a good attachment point? Thanks.
Old Sep 28, 2004 | 02:57 PM
fishmanndotcom's Avatar
fishmanndotcom
normally with ttb setup you have the inverted-Y steering and instead of mounting the stabilizer on the axle most ppl attach it to the frame on either side. make a bracket that will sandwich the frame rail with a small piece of the bracket hanging down beyond the frame rail. then just drill a hole and voila! your done
-cutts-
Old Sep 29, 2004 | 05:51 PM
Chris_ce's Avatar
Chris_ce
Mine came with a 6x2in flat peice of 1/4in steel two bolts into the frame rail. Pretty much as fishman said. Works great with no complaints.
Old Sep 30, 2004 | 04:57 AM
s1120's Avatar
s1120
Any pic's of these mounts? I think I understand, but yopu know what they say. A picture is worth a thousand words.
Thanks!!
