Oil & Lubrication
Assembly lube ideas?
Old Sep 28, 2004 | 12:00 PM
rusty70f100's Avatar
rusty70f100
Since I will be building a 390, I need some ideas for assembly lube. You know, the stuff you smear on the cylinder walls, rocker tips, and bearings. Here's what I was thinking:
1 part 40 weight motor oil
1 part STP
1 part Moly grease
Thoughts?
Old Sep 28, 2004 | 12:41 PM
jschira's Avatar
jschira
1 part STP
1 part Moly grease
Thoughts?
I'd use something like this:
http://www.motostrano-store.com/noname.html
Or this:
http://www.cranecams.com/?show=brows...15&showAll=yes
$4-$5/tube, why screw around with mixing your own?
BTW - Did you see the Crane Super-Lube ZDDP anti-wear additive? $8.50 for an 8 oz. bottle at Summit Racing.
Old Sep 28, 2004 | 01:05 PM
cmlind's Avatar
cmlind
I am getting close to done on my 302. I used Permatex assembly lube. Looks to the crane super lube. It was red, semi liquid and real sticky. My machine shop recommended it.
I think all of the above are good. Anything that will stay in place and has anti wear additives is good. I agree with jshira. Unless you are really exited about making the stuff, it would be just as good and easier to buy one lube. You don't really need that much anyway... well a 390 probably takes more than a 302. I used 1/3 of the bottle.
Old Sep 28, 2004 | 02:21 PM
rusty70f100
Hrm, looks like they have more than just the moly cam lube. Thanks for the links.
Old Sep 29, 2004 | 11:16 AM
96er's Avatar
96er
MotorKote is supposed to come out with a grease soon. I have heard that they began testing this summer. I have used Slick-50 grease with some MotorKote added to it for everything that needs a heavier lubricant.
I don't know if it's for sale yet.
http://www.motorkote.com
Old Sep 29, 2004 | 01:38 PM
jimandmandy's Avatar
jimandmandy
GM (I know) engine oil supplement.
Jim
Old Sep 29, 2004 | 07:26 PM
BlueRanger94's Avatar
BlueRanger94
I used Permatex assembly lube when I built my 350. Crane Cams makes a brake in additive which was included in the cam kit.
I have also used moly grease and STP.
Old Sep 30, 2004 | 11:35 PM
Broncojohn's Avatar
Broncojohn
I use lubriplate #105. I think I bought my last tube at NAPA. Its designed for engine builders. I've used it for years on my aircraft and auto motors. Its designed to stand for a while, if you have to sore a motor.
Old Oct 1, 2004 | 04:23 PM
kotzy's Avatar
kotzy
I'll second the motion for Lubriplate has zinc in it and works well on tappets and cams.
If the engine is going to be fired up in a day or so after assembly the rings and bearings
got a liberal application of engine oil, and the pump was always primed.
Old Oct 7, 2004 | 11:19 AM
coker0290's Avatar
coker0290
For your bearings use the motor oil you are going to run in it. I work in an engine building shop and thats all we ever use.
Old Oct 16, 2004 | 02:11 AM
ford390gashog's Avatar
ford390gashog
and don't oil the outside of the bearings
