1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Snow Plow under-carriage Pictures and help please
Old 09-27-2004, 06:41 PM
w9sn's Avatar
w9sn
w9sn is offline
I traded a guy for this Meyer undercarriage for my old Dodge one. He assured me that this came off of his 2002 Ford superduty. I have a new 2004 superduty and I am either not looking at this right or this is the wrong one.
Here is the pictures:
http://www.w9sn.com/snow.htm
The bumper is hitting the top of the corner of the carriage. I don't see a way of mounting it inside the bumber. Does this look like the right one for my truck??
Or am I totally missing how to bolt this up? Did they make a frame change in 2 years?
Thanks in advanced guys....
Old 09-27-2004, 06:48 PM
02superstroker's Avatar
02superstroker
02superstroker is offline
it won't fit inside (behind) the bumper?
Old 09-27-2004, 07:04 PM
w9sn's Avatar
w9sn
w9sn is offline
If you look closly at the side views, you can see that even mounting it behind the "top" part of the bumper, that it would hit the lower part. I am almost convinced that this is not the right undercarriage.
Old 09-27-2004, 07:57 PM
02superstroker
The bottom part of the bumper will come off.
Old 09-27-2004, 08:05 PM
w9sn's Avatar
w9sn
w9sn is offline
I didn't realize that....I will start tearing it down tomorrow...thank you...
Old 09-27-2004, 08:36 PM
04superduty's Avatar
04superduty
04superduty is offline
the bottom part of the bumper comes off, 3 nuts on each side. the piece that comes off prevents cars from going under you if you rear end them. you must have that on, or the plow under carriage so you should save it.
to remove your bumper there is 2 bolts on the front on either side and then one inside each fener well. you can remove and install the bumper your self but it helps to have some help. good luck
Old 09-27-2004, 08:42 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
That part won't fit anything but a Super Duty..
Old 09-27-2004, 08:43 PM
w9sn's Avatar
w9sn
w9sn is offline
Thank you so much!!
Old 09-27-2004, 08:46 PM
w9sn's Avatar
w9sn
w9sn is offline
I am guessing that I also have to remove the plastic covering that is over the lower part of the bumper as well....
Old 09-28-2004, 11:21 AM
slc10844's Avatar
slc10844
slc10844 is offline
Is that all the parts you have? There should be additional brackets and special mounting hardware. Send me your fax number and I will send you the installation instructions.
Old 09-28-2004, 05:33 PM
w9sn's Avatar
w9sn
w9sn is offline
I got it done!!!
OK I am finished with it and now ready to put the blade on (when the snow arrives) It took me 3 hours to get it all done. The entire bumper must be removed then there is a cross-member that also has to be removed. I just put new pictures up on my website for you to look at. I guess this would help anyone wanting to do the same thing.
Have fun guys and thanks to all who have helped me figure this out!!
Old 09-28-2004, 07:39 PM
04superduty
i see you went through the joy of drilling through the frame, what fun that was, and only I went through 1 bit.
Old 09-28-2004, 08:12 PM
w9sn's Avatar
w9sn
w9sn is offline
It wasn't too bad. I had to go through it 5 times. 2 bolts only go through one side. The other 2 go though boths sides of the frame. On the driver side, I got lucky and found a hole (factory) directly lined up with the one I drilled. The passenger side didn't have that hole....grrrrr.
All in all, I have to say that after doing this to 2 Dodge trucks, the Ford was easier. The Dodge was a 6 hour ordeal both times and nothing lined up right.
By the way, I used a "hole cutter" bit to do it and it took about 1 minute to drill each hole. The bumper surprised me on how light weight it was.
Old 10-09-2004, 07:29 PM
UnderTakr's Avatar
UnderTakr
UnderTakr is offline
Anyone have the wiring diagram for the nightsaber lights for the SD? I get the headlights to come on but the turn signals wont come on.
Thanks,
Jeff
Old 10-09-2004, 07:45 PM
dougger222's Avatar
dougger222
dougger222 is offline
A few years ago a friend and I who had never even come close to a snow plow decided we could save the $3-500 installation charge and do it ourselves. I bought a two year old complete set up off a 99 F350 and had it on the 99 F250 in under 3 hours. Only a couple times we had to drill out a hole that was too small for the factory Western Pro Plow bolt. It takes no time to take off the bumper and the mount goes on pretty quick. It also helped having impact tools with two good socket sets.
Quick Reply: Snow Plow under-carriage Pictures and help please
