Disc Brake conversion
Old Sep 27, 2004 | 06:33 PM
bfletcher101's Avatar
bfletcher101
1979 ford f 100
i have a 1979 ford f 100. i would like to convert the four wheel manual drum brakes to four wheel power disc brakes, any help would be greatly appreciated.
i would also like to drop in a 300 six cylinder in place of the 351m i assume the motor mounts are different? and last but not least i would also like to add an automatic trans. with overdrive any help? i know it sounds as though i would like a brand new truck but that is not the case the old stuff just looks better and is a lot eaiser to work on. thanks
Old Sep 29, 2004 | 11:22 AM
73Custom's Avatar
73Custom
Welcome to FTE...
Is this a 2wd or 4x4?
All '79 F100s came with front disc and rear drums. Power brakes was an option, adding a booster and pedal will give you power brakes. The front disc/rear drum is a good setup and will stop well. Kits are available to add rear discs, I believe they run about $400-$600.
A 300 will fit but you need to change the motor mounts, exhaust, carb linkages, tranny, radiator, accessory mounts and other small things. Why do you want a 300 over the 351M?
Auto with overdrive from a newer pickup can be installed and has been done. Check the past posts for details.
My '73 is slowly becoming a new truck too... I prefer the look/feel of the old iron too.
Marty
Old Sep 29, 2004 | 06:56 PM
Grumpy54's Avatar
Grumpy54
you would also have to change the stamped metal supports for the 8 cyl to 6cyl as well as having to change tranny mount Xmember postion. The only other problem I can forsee would be the wiring locations
Old Sep 30, 2004 | 06:07 PM
bfletcher101
hey thanks
thanks for the info. the reason that i want to drop in a 300 six is because i think i may get better gas mileage and everyone i talk to say it is a good, strong, and reliable engine. thanks again
bfletcher101 oh yeah the truck is a 2 wheel driveQUOTE=73Custom]Welcome to FTE...
Marty[/QUOTE]
