Sponsored by: Auxito
99 F150, Won't Start
Old Sep 27, 2004 | 02:49 PM
gfreek's Avatar
gfreek
This morning, turned the key to start, it would start, but as soon I put the key in run position, it would stall. It did this 3 times then it stayed running. Now this afternoon, it did the same thing, however I found that if I feathered the gas I could keep it running and drive it home, 4 miles. It also does not idle right, when it does idle. It has a 5.4. Thanks
Old Sep 27, 2004 | 02:57 PM
PaulC's Avatar
PaulC
99% likely that your truck has a bad or dirty IAC (idle air control) valve. Do a site search on IAC replacement.
