$170.00 Mistake... Don't Tap!
Old Sep 27, 2004 | 02:20 PM
Les100's Avatar
Les100
Post $170.00 Mistake... Don't Tap!
Washed the motor on my 1997 psd while it was warm. Drove approx. 4 blocks and the truck D.O.A.'D. Wouldn't start. 30 minutes later it did start and i hobbled it home. Engine check light was on and the truck ran real rough and would hardly throttle up. I started doing what any good machanic would do and began tapping on things. Well I tapped so hard on the ICP and boke the plastic tip/plug in. After I broke it I removed the plug-in and it was full of water. A local dealer had a ICP at the tune of (with tax) $170.00. Truck is running strong again. The supplemental owners manual says DO NOT WASH THIS ENGINE WHILE IT IS HOT, WARM OR RUNNING AS IT CAN CAUSE SERIOUS DAMAGE TO THE FUEL SYSTEM. I read this after all of the above, just passing it on, might save someone from the same fate. AND DON'T TAP.
Les
Old Sep 27, 2004 | 10:30 PM
truck_guy's Avatar
truck_guy
steam is an engines worst friend
Old Sep 27, 2004 | 10:40 PM
RickyBR's Avatar
RickyBR
I'm glad you posted this. I was gonna get some degreaser this weekend to clean my motor and I was thinkin to myself that I was gonna leave the motor idle while I cleaned it.
