Bronco II Ford Bronco II
3.73 capabilities
Old Jul 17, 2001 | 04:40 PM
nicebronc2's Avatar
nicebronc2
3.73 capabilities
I have 3.73 gears in my 85 broncoII. It has the stock 2.8L v-6 in it. Will I be able to comfortably turn 32x10.5 tires with this set up? Will my acceleration be changed in any way? Any info on this topic would be greatly appreciated.
Old May 22, 2002 | 11:23 AM
Shuby's Avatar
Shuby
3.73 capabilities
WEll hear is a question! what size do you have on it right now? Do you have a lift kit installed, and do you mind the tires rubbing? I mean if you are going to put 32 X 10 tires on you BII and you pressently have P225/75/R15 tries on it. YES you will see a great differents! a los in acceleration, power, and gas mileage! if you do not have a lift kit you will really mess up your finders! as far as I know the biggest tire you can put on a BII is a 30 X 9.5 and they rub in the fron't fender walls, and on the top of the rear wheel wells! good luck on it though! Hope this helps!
Old May 22, 2002 | 12:37 PM
alf4444's Avatar
alf4444
3.73 capabilities
