Adding Amp to 03 Expy
Old Sep 27, 2004 | 07:47 AM
mtnman64's Avatar
mtnman64
Is it possible to just add an amp to the stock 6 CD/stereo in the 03 Expy? The volume level/sound is not so great, but don't want to put a ton of money into it, so was thinking that I might be able to just add a small amp to boost it a bit.
Old Sep 27, 2004 | 10:09 AM
daveplot's Avatar
daveplot
You would need somthing like this, a Line Output Converter since the head unit doesn't have any preamp outputs. If your going to amp your speakers you should replace the stock ones with ones rated at more output.
Old Sep 27, 2004 | 11:44 AM
mtnman64's Avatar
mtnman64
Is it absolutely imparative that I replace the stock speakers?? Or is there an amp that will work to increase the volume without blowing the stock speakers?
Old Sep 28, 2004 | 10:48 PM
Matt03Expy's Avatar
Matt03Expy
Yes. If you are going to bother adding an amp, changing the speakers is a piece of cake. BTW, the stock speakers are paper wizzer cones, unless you have the audiophile stereo.
Old Oct 15, 2004 | 04:35 PM
blwilli's Avatar
blwilli
I know you don't want to get pricey.....but
if you're adding an amp, you may as well replace the speakers, and the head unit, new changer...etc. You would be amazed how much a diference just an aftermarket head unit would make...let alone speakes and an amp. those stock stereos aren't all that great. fist thing i did was pull mine, and replace it with an Alpine...10 times better...even before I changed out the speakers.
