Got a vibration
Old Sep 26, 2004 | 10:57 PM
79F150400M's Avatar
79F150400M
Got a vibration
Not speed related...when I bring the R's up to 1500 I get a semi-obnoxious vibration. Back off and it goes away...go above 1500 and it goes away. Whatya'll think???? Oh yeah...noticed also that i have gas leaking from pass. side of the Carter AFB from throttle shafts
Old Sep 27, 2004 | 09:18 AM
paragod's Avatar
paragod
I'd fix the carb leak, then check and see if you have a bad plug wire, or something else in the ignition. You might just have a plug wire grounding out.
Old Oct 2, 2004 | 10:19 PM
Loan Ranger's Avatar
Loan Ranger
It also could be a loose or overly-tight torqued motor mount.
Old Oct 4, 2004 | 02:04 PM
79F150400M's Avatar
79F150400M
I know my plug wires are good...have a Taylor set thats maybe 1yr old with not alot of miles. I'm suspicius of carb and I'll have to explore the motor mount ideer. Really appreciate everyones input...this website ROCKS!!
