What kind of shocks do you suggest and why?
One thing to remember is that there is a good possibility that most lower priced shocks are made by the same company and just have a rancho, heckthorn, procomp, fabtech, ezride, superlift, or skyjacker sticker on them, to get into a shock with more disign and thought put into them you will be looking at a considerably higher price, if you don't mind paying a little more for a good shock I would see what blistien offers for your truck, the rancho RS9000 is a good shock and the adjustability is nice to but they are also a little pricey, Iwould stay away from the lower priced ranchos (RS5000) and procomp shocks, form my experience I thought they were a little rougher riding shock, I also have the skyjacker hydros and superlift hydros (almost certain they are the same shock) they are not to bad but if I new what I know now I would have gotten the Blistiens instead, If money is no object the King shocks or Fox shocks are cream of the crop, but you better be ready to bed over when you order them,
my current project truck will be running the King coilovers so I've already looked at there prices, looks like I'll be bending over this spring,
Originally Posted by fishmanndotcom
basically a hydro uses an oil type liquid that moves through valves and cycles through the ups and downs of rough terrain....gas shocks on the other hand are pressurized which it is constantly pushing up.
you take a gas and a hydro and set them side by side....compress the gas one by hand and it will spring back, do the same to the hydro and it will stay!
i don't think the gas shocks have as bad a problem with heat as the hydros do and heat is a bad thing cause it will cause the shock to fade and the ride will get rougher
-cutts-
-cutts-
lol none of the hydro shocks i have ever installed (rancho, skyjacker, superlift, and trailmaster) don't spring back up, and all were brand new. think about the physics....a pressurized tube would but a liquid filled tube more than likely won't!
i am just merely stating what i have found to be true on my applications
-cutts-
-cutts-
-cutts-
-cutts-
so I eat my words..
So do the hydros give a rougher ride-somebody asked earlier and I didn't see a response. I have a 79 also, but a 150, with quad shock set up in front-I could use some advise on whether the hydros or gas will make the ride rougher. Right now it could be a little softer-Im running the cheap pro comps.
#28
I had cheapie nitros on my f-150 and they rode great...
#29
#30
Gabriel Gas adjust from Pep-Boys. 24$ a shock and they ride pretty good at speed. On the slow stuff they are a little too soft and tend to bounce, but once up to speed they are pretty good. If you want cheaper get the red gas shocks at 15$ each. For really Cheap you can get the blue hydros for around 12$ each sometimes 7-8$ each.
Bilsteins are really good, but pricey. They claim to have 100,000 mile warranty, but the ones on my Tacoma were shot at 50K highway miles. So I don't know about that 100K thing.
