wiring diagrams
Old Sep 26, 2004 | 04:15 PM
65_all_the_way's Avatar
65_all_the_way
wiring diagrams
i need a wiring diagram for a 65 ford f-100 i got new taillight and i need help with wiring them up
Old Sep 26, 2004 | 05:55 PM
Loan Ranger's Avatar
Loan Ranger
Try www.motorhaven.com or www.helm.com. If you can't get one from either of those places, check and see if a book dealer offers a Haynes shop manual that will cover the 1965 F-100.
Too, by chance, did the tailights you bought come with any instructions? Some will and the instructions usually include a wiring diagram.
In the meantime, I will hunt and see if, perhaps, I have a diagram to cover a 65 for you.
Good luck!
Old Sep 26, 2004 | 06:06 PM
Loan Ranger
Yes, I found my wiring diagram set for your truck, 65alltheway. Regarding the tailights, on the LEFT HAND SIDE, the BROWN wire is the feed for the taillight; the YELLOW wire with the BLACK STRIPE is for the signal light; the BLACK wire is the ground. On the RIGHT HAND SIDE, the BROWN wire is for the taillight; the GREEEN wire is for the signal light; again, the BLACK wire is for the ground.
Both black wires go to a common ground, usually located at the right rear of the truck.
I surely hope this is of some help to you!
Old Sep 26, 2004 | 10:17 PM
65_all_the_way
thanx
hey thanx for your info it was very help full
Old Sep 27, 2004 | 10:29 AM
Al_V's Avatar
Al_V
Check this:
http://www.tocmp.com/tOCMP/wiring/1964F100/index.htm
