c6 shifts
Old Sep 26, 2004 | 01:10 PM
smoke n tires's Avatar
smoke n tires
c6 shifts
in my 78 when i first got it, the c6 shifted very early and soft. this is not usual for a c6. i adjusted the int. band and found the vac mod to be adjusted all the way out. i screwed it in most of the way and dramaticly changed the shift points and qaulity. has anyone else had this problem? i hope my trans is ok with the new adjustments, cuz it had been the other way for so long...i would also like some advise on a street shift kit, are they bad to install?
