oil pan clearance problem
Old Sep 26, 2004 | 11:40 AM
bhawkin2's Avatar
bhawkin2
Smile oil pan clearance problem
I have a 78 f-250 the oil pan sump is in the front and when the front Diff flex's it hits the oil pan. My other truck same year.The sump is in the rear.Did some one put a car motor in it? Or is that the way it supposed to be?It's a 351m,I think? I havent run the numbers yet.Any one know thanks.
Old Sep 26, 2004 | 11:56 AM
jimmieg2's Avatar
jimmieg2
It sounds like a car oil pan with the oil pump in the front.
its a common swap to use a engine from a 2 wheel drive or a car since they can usually be bought cheaper just get a differnt oil pan and pump and you`ll be fine
Old Sep 26, 2004 | 12:10 PM
73f350sc's Avatar
73f350sc
Yeah it either sounds like it was replaced with an engine from a car, or someone somewhow mamged to get everything on backwards when they put it on.
Hope it helps,
-Chris
Old Sep 26, 2004 | 02:11 PM
bhawkin2's Avatar
bhawkin2
Smile Oil pan clearance.
Thanks for the help.Does anyone know where I can get a oil pan,pump and screen? So that I can put the sump in the rear to get it away from my Diff?
Old Sep 26, 2004 | 07:30 PM
supercab4x4dually's Avatar
supercab4x4dually
Jeff's Bronco Graveyard.
Old Sep 26, 2004 | 08:18 PM
jimmieg2's Avatar
jimmieg2
Talking
these guys have everything you need to fix up any FORD bronco or truck.
I`ve been dealing with them for years
Old Sep 26, 2004 | 09:05 PM
supercab4x4dually
Done alot of spending with JBG myself,and everytime it was 100% a pleasure dealing with them!Jimmieg2 is dead right.They have what ever you need,and then some.Just my apinion though.
Old Sep 26, 2004 | 09:08 PM
rlangs58's Avatar
rlangs58
Thats nice but the Grave Yard sure can't come up with a dip stick tube 7 stick for my
84 F-150 C-6.
rlangs58
Old Sep 26, 2004 | 09:19 PM
jimmieg2's Avatar
jimmieg2
Angry
84 F-150 C-6.
rlangs58
they had them last night when i wasss browsing through theree parts for my 85. Did you ask them for tech help at the bottom of their pages?
They have what you need for your ford truck from 66-present
Old Sep 26, 2004 | 09:26 PM
jimmieg2's Avatar
jimmieg2
Hope it helps,
-Chris
a 351m oil pan CAN NOT be put on backwards, look at one and you will see why, one side is different from the other as well as the rear seal is bigger than the front seal
Old Sep 26, 2004 | 11:08 PM
supercab4x4dually
If it's in the pan ive used 3/8's steel tubbing,and used the old threaded part that goes into the pan,and just bent it to match my old tube.Then after I was done I do a oil change,and make sure you made the tube the right length.Ive done this on a couple of our street warior's.Worked good,no leak's!Just a thought if you can't find what you need but im sure you will.
Old Sep 27, 2004 | 10:39 AM
460429_freak's Avatar
460429_freak
sounds like a car pan... I did the same thing with my 79 butttt I had 6 inch left so I was okay.... you will have to get a pan pick up tube with screen.... you can change the pan without pulling the motor but it is a pain...
Old Sep 27, 2004 | 04:52 PM
bhawkin2's Avatar
bhawkin2
I've put a oil pan an pump in my other 78 so I know how much of a pain it really is .I have a lift in my garage so it makes it a little easier on me.Thanks for all your help guys I'll give JBG a call.For the oil pan an screen
