Tapping Into Warning Buzzer/Chime
Old Sep 25, 2004 | 11:45 PM
MemOrex's Avatar
MemOrex
I recently installed some aftermarket foglights and was wondering if i could somehow tap into the chime/buzzer noise so i know if i left the lights on.
Can it be done? Any suggestions greatly appreciated.
Old Sep 26, 2004 | 04:27 AM
MustangGT221's Avatar
MustangGT221
An easier way would be to wire it to a keyed source so the lights shutoff if you turn the key off.
Old Sep 26, 2004 | 03:15 PM
FordPerf300's Avatar
FordPerf300
I agree with mustang.
Tho. Another way is you would have to tap into the hot lead in the headlight switch with a solenoid. When you turn on the headlights that solenoid will get 12v which can be wired to the fog light switch, when the switch is turned on it will power up another solenoid for the lights... make any sense?
Old Sep 26, 2004 | 10:25 PM
MemOrex's Avatar
MemOrex
Ah, thanks for replies guys. Im gonna do the keyed source method. Thanks
Old Sep 27, 2004 | 08:18 AM
4x4fordtrkn's Avatar
4x4fordtrkn
I ran my aftermarket foglights from one of the parking lights. That way I had to turn on at least the parking lights for the foglights to come on. I wired it as follows:
1- run wire from parking light to switch for foglights
2- run wire from switch to foglights
3- run wire from foglights to ground.
Hope this helps.
Old Sep 27, 2004 | 10:15 AM
dan1101's Avatar
dan1101
Watch out, in some states (like Virginia), your vehicle won't pass inspection if the fog lights can turn on with parklights only.
Old Sep 27, 2004 | 04:45 PM
4x4fordtrkn
With it wired like i stated above on most fords I know when you turn the headlights on the parking lights are also on.
