Sponsored by: Auxito
Bounce During Braking
Old Sep 25, 2004 | 07:10 PM
Brent Standiford's Avatar
Brent Standiford
Thumbs up Bounce During Braking
HELLO EVERYONE I'M NEW HERE And I have a question about my 1998 ford f-150 4x4,when I use the brakes my truck starts to bounce, so I replaced the tires and brakes thinking this would solve the problem but have the same results any ideawhat to check for, maybe shocks.
thanks and howdy
Brent standiford
Old Sep 25, 2004 | 07:23 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Enjoy FTE
Click on this link and post your question in the 98 F150 forum
https://www.ford-trucks.com/forums/f...splay.php?f=25
Old Sep 25, 2004 | 10:19 PM
Racerguy's Avatar
Racerguy
Hi Brent and welcome
Did you replace the pads and shoes? Rotors and drums too?
Usually the problem you're describing is caused by warped rotors or drums.
Old Sep 26, 2004 | 11:00 AM
blueharley's Avatar
blueharley
I've had this problem on my 82 F-150 as well as my 98. My experience is that there is a warped rotor or drum out of round. You can try machining them and if that fixes it good. I have been told the metal takes a "set" when casted and may warp again when it heats up. My 98 has 98K on the original pads and shoes with the same problem. When I get ready to change the pads and shoes will probably have the drums and rotors machined. The problem seems to come and go depending on how hard you get on the brakes. Good luck.
