Redo
Old Sep 25, 2004 | 04:01 PM
wickymustang's Avatar
wickymustang
Redo
I have a 95 F150 that I am looking into completely redoing after I finish school here. I have started to go through and get ideas of what needs to be done, I know that the motor wil eventually need to be done, new seals, rings, ect. I want to make this already stout motor completely bullet proof. I'm not looking for enough torque to pull a football stadium, or a top speed of mach 7, but I want to beef it up past stock. What all would be involved and should I keep it EFI or go to a carb?
Old Sep 26, 2004 | 01:27 AM
85e150's Avatar
85e150
What tranny?
I'd stay EFI and ask about balance and blueprint costs, and possibly bumping the compression a point or two if I could get it as part of the deal....
You could do some head work, see other comments as I think the exhaust is really bad.
I ask about tranny because the engine has good power but a narrow powerband. If you have more gears you can make better use of your power.
Do you have to smog--a 95 has to pass at the pipe and visual in CA, so no cutting the cats or three carbs or any of that...
Good luck.
Old Sep 26, 2004 | 11:06 AM
wickymustang
I'm in MN, no testing anymore. By the time I touch the truck it will be old enough to do whatever I want. Right now it has a M5OD, but when I redo it will be a ZF5. Already have custom exhaust too
