Blown head gasket???
Old Sep 25, 2004 | 01:57 PM
mike L's Avatar
mike L
I hear a load boiling sounds (at the engine ) every time I turn off the truck. It lasts about 10 seconds.I have a small pinhole in my radiator, could this be letting air in??? Its been like this for 8 months, runs fine, good power runs smooth. I don't have any white smoke at exhaust. Do I need to do a simple compression test to check? Antifreeze goes down very little, but could be the small pinhole in the radiator?? Thanks 87 f150 4.9
Old Sep 25, 2004 | 04:10 PM
rick90yj's Avatar
rick90yj
run a can of radiator stop-leak through it, and see if that makes a difference.
I doubt it's a head gasket. Check the thermostat, too. Does it run hot, or is it running in the midrange?
Old Sep 25, 2004 | 08:32 PM
mike L's Avatar
mike L
Coolant blockage???
Tried a can of raditor stop about two months ago. The therostate was replaced, last year. It never runs hot, midrange all the time. I wounder if there is a coolant blockage?
Old Sep 26, 2004 | 06:35 PM
rick90yj's Avatar
rick90yj
get a flush kit and flush the system good. It takes about a half hour to install and flush.
