Sponsored by: Auxito
air bypass valve
Old Sep 25, 2004 | 11:40 AM
wagon burner's Avatar
wagon burner
air bypass valve
i have a 97 f-150 v6 the check engine light came on, the last time it come on they said it was the air bypass valve after they replaced it the light went out 2 years later it is on again i had them hook it up to the computer it said air bypass valve bad i noticed a allen wrench screw in the front of the valve is there a way to adjust this or just get a new valve
thank you
Old Sep 25, 2004 | 05:59 PM
wagon burner
well the computer diagnostic was wrong again while i was checking under the hood again i found a hole in the pcv valve hose i changed that out for 15.00 the truck runs smooth again and the check engine light went out the dealership wanted around 300.00 to change out the air bypass valve
Old Sep 25, 2004 | 10:22 PM
Racerguy's Avatar
Racerguy
Good to hear that you got it solved
Did you get your dealer or someone else to scan it for you?
Old Sep 26, 2004 | 12:40 AM
RustyWallace's Avatar
RustyWallace
good job
i did mine my slef as well
Old Sep 26, 2004 | 08:02 AM
wagon burner
the local ford dealership ran the test 59.00
