engine won't idle
Old Sep 24, 2004 | 10:00 PM
camccardell's Avatar
camccardell
Unhappy engine won't idle
engine won't idle.
I decided to upgrade my radiator the other day from a 1 core aluminum to a 2 core aluminum.
not a bad idea, I mean I had to get diffirent hoses since it was set up for an automatic trans and I have a stick.
93 ranger buy the way.
anyway started makin a noise on the highway, so I clicked it off and it siezed.
Stopped and the radiator hose (lower) had blow completey off and the truck was dry.
after the tow home i realised that water was getting into the cylinders, so I pulled apart the engine and installed all new gaskets; didn't do a whole rebuild since I did one just about 20k ago.
The engine runs now, but won't idle right, and shakes all over the place.
put new spark plugs, wires, cap and rotor on again
redid the timing again.
and still it is doing the same damm thing
any ideas?
thanks
Chris
Old Sep 24, 2004 | 11:43 PM
silvapain's Avatar
silvapain
Vacuum leak maybe? What's your vacuum at idle when at operating temperature?
Old Sep 25, 2004 | 08:36 AM
camccardell
about 15
Chris
Old Sep 25, 2004 | 05:19 PM
hreed's Avatar
hreed
Did you check the compression? Which gaskets did you replace? When you checked the vacuum, did the needle hold steady at 15, or was it bouncing around? Does it shake all over the place only at an idle, or all the time? You need to do some more troubleshooting to find this problem, and I think compression and vacuum are the first places to start. Keep us posted.
Old Sep 26, 2004 | 06:05 PM
silvapain's Avatar
silvapain
Originally Posted by camccardell
about 15
Chris
Wow that's low. It should be around 20 inHg at sea level. What's your elevation?
AMG-SM
29
Sep 9, 2019 11:47 AM
nitronick
1997 - 2003 F150
Nov 30, 2013 04:16 PM
2FordTrucks
15
Oct 20, 2013 10:38 AM
holymolie
22
Mar 29, 2011 12:54 AM
sfitzgerald351
1978 - 1996 Big Bronco
64
Jan 15, 2005 04:27 PM
