Bronco II Ford Bronco II
Just got a 89 B2 with problems...........
Old Jul 26, 2002 | 05:19 PM
num1goalie's Avatar
num1goalie
I just bought a 89' b2 from an auction........... It runs but when I tried to drive it to my house the highest it would let me get was 30 mph with extremely slow acceleration, and when i was sitting at a light the engine just quit on me......... the car was sitting in the sun in the car lot since may and so i figured that if i got some fresh gas in it, a new battery, and changed the filter it should run a bit better.........
Im going to be working on it tomorrow and was just wondering if any of you had any other suggestions or info that would help me to get this thing up and running..........
Old Jul 26, 2002 | 07:44 PM
Avanti's Avatar
Avanti
I would check all the fluids. Change oil & filter, air & fuel filter. Check plugs, plug wires, distributor cap & rotor and replae if look old,worn, corrodet er. Pressure check the cooling system before you change the antifreeze. Grease etc. Pull all wheels & check brake pads & shoes for thickness or fluid leak. I too haqve a 89B2.
Old Jul 29, 2002 | 07:05 AM
adbradley's Avatar
adbradley
You may have a bad transmission. I had an 89 with a 4 speed auto (A4LD) that would barely pull itself due to slippage. It had a top speed of 50 mph on flat ground...
Old Jul 29, 2002 | 12:22 PM
AbadDriver's Avatar
AbadDriver
Post Just got a 89 B2 with problems...........
with the tranny problems the a4ld is a notoriusly(sp) bad transmission......but one thing that might help a little bit is take it out of overdrive when not on a highway...it helps a bit on my 86 b2
Old Jul 30, 2002 | 07:53 PM
rebocardo's Avatar
rebocardo
Critterhunter
1983 - 2012 Ranger & B-Series
Jun 17, 2015 05:11 PM
MI79250
19
Dec 31, 2011 12:18 PM
Minion00
Nov 28, 2011 01:24 PM
Econoline 150
General Automotive Discussion
85
Jun 16, 2009 11:20 AM
orion96
Bronco II
Feb 19, 2005 05:42 PM
