Headers for '95 efi 300?
Old Sep 23, 2004 | 08:54 PM
4.9LFord's Avatar
4.9LFord
I've got a '95 300 and the only headers i can find are for older models of the 300. has anyone found headers for the newer 300's or put these headers from the older ones on?
Old Sep 23, 2004 | 10:40 PM
85e150's Avatar
85e150
Many threads about using EFI manifolds on older engines, saying "almost as good as headers". Are you beefing this up to turn higher revs....?
Old Sep 23, 2004 | 11:23 PM
50_Buck_Work_Truck's Avatar
50_Buck_Work_Truck
I think Clifford makes such an animal, but it'll likely cost more than is reasonable.
Yep, and the plumbing's a bit of a PITA...welding/brazing, and fitting skills required...if this doesn't sound like fun, might think of saving yourself the aggro: the EFI manifolds do ok on the low end (where the engine makes the most of its usable power anyway). If a little custom-fitting (O2 sensor bung, EGR feed, bracket clearance, exhaust fabrication, etc.) or wallet-stretching doesn't bother ya, go for it! They do make a difference, but it's up to you to decide how cost-effective it is.
