how do you program Keyless Entry Remotes ?
Old Sep 23, 2004 | 04:37 PM
timmyjoe's Avatar
timmyjoe
Hallo
I have a 2000 explorer sport.
Old Sep 23, 2004 | 05:02 PM
southernfordman's Avatar
southernfordman
i think you get in and turn it on and off but dont start it about 9 or 10 times maybe more but the door locks will go crazy locking and unlocking itself and then you hit lock on the keypad
Old Sep 23, 2004 | 08:02 PM
JerrySimm's Avatar
JerrySimm
Here's what my 2003 owners manual says;
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four)
available before beginning this procedure.
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 1 (LOCK) position to 3 (ON).
4. Cycle eight times rapidly (within 10 seconds) between the 1 (LOCK)
position and 3 (ON). Note: The eighth turn must end in the 3 (ON)
position.
5. The doors will lock, then unlock, to confirm that the programming
mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry
transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 1 (LOCK) position after you have finished
programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
mode has been exited.
You should probably check your manual to make sure it's the same.
Good Luck...........
