Offroad & 4x4
Dash
Old Oct 12, 2004 | 12:12 AM
  #31
mustange70's Avatar
mustange70
What are the odds, that about right then with the speedo and tach. That bling gauge fits you perfect, now just need to find a way to hook it up to a decibe meter or something so the louder your truck the more bling you have, or something of the like.
Old Oct 12, 2004 | 12:48 AM
  #32
ivanribic's Avatar
ivanribic
If I do a fuel pressure guage I just need the 15PSI, not the 100PSI, correct?
Old Oct 12, 2004 | 02:18 AM
  #33
highboy1975's Avatar
highboy1975
it's been awhile since i checked this thread, that's gonna look pretty cool, i definately like it. maybe since you know how to do it already you could sell something similar and make some cash off the idea. i wander what my mom would have to say if i started hacking up cupboard doors around here, i dont think i want to find out though.
Old Oct 12, 2004 | 06:09 AM
  #34
bremen242's Avatar
bremen242
unless you do an EFI swap, 15psi is all you need. Make sure you get an isolator.
all I'm gonna ask is why a 160mph speedo?? I'd like to see that happen
Old Oct 12, 2004 | 10:13 AM
  #35
proeliator's Avatar
proeliator
Yes, only the one that goes up to 15 psi. Once you build your engine you should have a regulator with the pressure locked in at 6-6.5
Bremen, they have electric fuel pressure gauges that eliminate the need for an isolator. Much safer.
Old Oct 12, 2004 | 10:37 AM
  #36
ivanribic's Avatar
ivanribic
Safer? After seeing the pictures Fishy posted of those wrecks I'm just going to pray to god I burn alive in my truck when I wreck it. I'm going to use a mechanical guage with an isolator. It was about $70 less to do that plus it's a lot simpler setup then the electric. I put that and a vacuum guage on my order but I've got to wait for an exchange on the flares so it could be a couple weeks before I see them. I'm thinking this will be all complete and installed at the end of the month now.
I really wanted a 120MPH speedo but they didn't make them in the 5". It was either 160 or 200. I could have bought a 3 3/8 speedo but that would screw up the balance here. This one is electronic so I can calibrate it with a button any time I switch tires or gears. I don't have to change out the speedo drive gear.
Including what I paid for paint (and what I paid the painter) I'd estimate I've got about $200 into the dash. That's not counting the guages of course which I'll total up this morning. I don't really need all the guages I'll have there but they look cool and I can't walk away from the bling. I've got a special adhesion promoter and vinyl paint for the dash pad. I did end up trimming a little more off the pad than I wanted but I think it will look fine. I'm going to paint it "buckskin" to match the leather seats I've got and the center console too.
Old Oct 12, 2004 | 07:12 PM
  #37
wizzard351's Avatar
wizzard351
cool idea man kinda looks like an old freighliner dash but for a pick up hope ya post pics after install
Old Oct 12, 2004 | 07:45 PM
  #38
ivanribic's Avatar
ivanribic
Shysters! I've got $870 into guages now. Autometer loves me. I ordered some switches the other day for my compressor and other misc. junk so I'll have to see how they look in there. I punched the holes for the 2" guages in the Lexan and they look great. I'm waiting to get a new hole saw before I attack the holes for the 5" guages. I think I'll pick up some blinkers tonight too.
Old Oct 12, 2004 | 08:15 PM
  #39
highboy1975
omg, 870 in gauges? did you type that right? thats insane, for 3 of your dash pods, i would have 1 of my truck and all my stuff
Old Oct 12, 2004 | 09:09 PM
  #40
bremen242's Avatar
bremen242
yeah. I've seen those.. The senders are like $250, at least if I remember correctly..
ivan, I feel bad for your girlfriend.. With all the money you spend on bling, you probably goto MickyDs for your dates..
Old Oct 12, 2004 | 10:08 PM
  #41
proeliator's Avatar
proeliator
Damn, I don't remember those fp electro gauges being that $
I dunno, last time I was up at Ivans his woman cooked us some of the best steak I'd ever had. I think Ivan sells plasma to afford his Bling
Old Oct 12, 2004 | 10:18 PM
  #42
fishmanndotcom's Avatar
fishmanndotcom
i've gotta get into whatever Ivan does for cash! it's gotta be slinging dope or something illegal...that's insane! you better hope those gauges last longer than your truck.
-cutts-
Old Oct 12, 2004 | 10:24 PM
  #43
ivanribic's Avatar
ivanribic
As I recall that steak kicked your butt Pro! When I'm down this weekend remind me to tell you the story about what I USED to do for cash. You'll get a kick out of that one.
Yes, $870 for all the guages, including the isolator for the fuel pressure guage. Summit has the electric fuel pressure guages for $195 with the sender. I spent $36 on the guage and $95 on the isolator . . . cheaper and more reliable. Looks like I'll have about $100-$150 in switches to be all blinged out. I just picked up a new hole saw and LED's for my blinkers. If I get a couple minutes tonight I'll pop it all in and snap a picture.
Old Oct 13, 2004 | 01:40 AM
  #44
ivanribic's Avatar
ivanribic
Couldn't resist hacking into it tonight so here we go, all I need now is to drill my holes for mounting it to the dash and then I'm ready to finish the guage panel. I installed LED's for turn signals as well as one for a high beam indicator. The little white spot below the high beam indicator is a warning light that will come on whenever my fans are turned off so I don't forget to switch them back on again. I've had that happen before and it's not pretty. I'm thinking I may use the stock light switch and mount it in the lower left corner by the guages. Still undecided as to the wiper control.
Old Oct 13, 2004 | 01:42 AM
  #45
fishmanndotcom
dude....Ivan, that is some serious kick-*** bling!
i have to say i am jealous
-cutts-
