Aerostar Ford Aerostar
Seat Belts
Old Sep 23, 2004 | 10:36 AM
drexvil's Avatar
drexvil
Seat Belts
1991 Aerostar 3.0 std
The seatbelt latch (female, the one that's bolted to the floor) is broken, it would not latch on. The dealer and small shops say that I'll have to replace the whole seat belt assembly because it's only sold that way. But the junkyard would sell just that unit for $25. I'm wondering if it's something that I can do myself with just hand tools (it's only 2 bolts) and if it's safe to reuse used seatbelt parts from the junkyard. Thanks!
Jack
Old Sep 23, 2004 | 10:48 AM
93nighthawk's Avatar
93nighthawk
1st, I would call around to other junkyards for a better price. I would pay $10 max.
2nd, easy DIY, as long as the belt is in good condition (no tearing or unthreading) and the latch works, it will be safe. Just be sure to torque the bolts down correctly. You don't want them to loosen up and cause the belt not to hold.
Old Sep 23, 2004 | 11:07 AM
copper_90680's Avatar
copper_90680
I think you also need Torx bits for it. It might even be the secured type where there is a small pin in the middle of the bolt head. In any case, it's easy, and you won't be compromising your safety. Also, I'm with Nighthawk. $25 is a ripoff. Nighthawk is being generous, I would rather die than pay more than $5 for it .
As for the torque on the bolt, I'll look it up tonight on my CD and post it for you if I can find it.
Old Sep 23, 2004 | 11:12 AM
drexvil's Avatar
drexvil
Thanks! You're both a great help!
Old Sep 23, 2004 | 10:20 PM
copper_90680
Drexvil:
The torque for the bolt on the seat belt is 22-30 ft-lbf
Old Sep 24, 2004 | 12:05 PM
tom_foreman's Avatar
tom_foreman
It is Torx but not the secured type.
Old Sep 24, 2004 | 04:03 PM
SgtJoe's Avatar
SgtJoe
I'm from California (originally) and $10 is what I would expect to pay at a pick-a-part or ecology yard. However I was stationed in NC (south) and had to replace the same part. Cheapest I found it for was $20 in a junk yard. The whole assy in the same yards was $80. Easy job, need a torx head to do it. Before you pull it, give the junk yard one several sharp tugs to make sure it will hold.
Easy job, spend the $20 for something that can save your life.
Old Sep 24, 2004 | 07:25 PM
JTHill24's Avatar
JTHill24
The bad side is that what breaks is a little piece of spring steel inside the buckle.
It is a weak point. What breaks is where it is folded over to hold it in place.
There is also two differant sizes that they use.
When I had to replace mine I popped open the buckle to see if that piece was cracked or half broken before I bought it. Didn't need to get one that was ready to break in a few days.
Jay
memobug
Aug 31, 2013 11:49 AM
obscurity
May 25, 2013 10:03 PM
firedaniel
6.7L Power Stroke Diesel
Sep 6, 2011 07:44 AM
Elitecrete1
Aug 20, 2011 04:35 PM
