?shorter stroke= more torque?
Old Sep 23, 2004 | 01:50 AM
nate5812's Avatar
nate5812
Question ?shorter stroke= more torque?
i'm not that knowledgable on the mechanics of engines. i enjoy dabbling around with friends that are mechanics. i've always understood more CID equals greater HP and TQ. i talking to a freind about stroking my 400 and he insisted that a shorter stroke has the potential to make more torque and a longer stroke makes more horse power. now this guy is not a mechanic and i wouldn't let him work on my truck, but hes one of those guys that knows about alot things about automobiles in general. so does what he said hold true to my disbelief?
Old Sep 23, 2004 | 02:08 AM
Torque1st's Avatar
Torque1st
Posting Legend
He has it backwards.
Old Sep 23, 2004 | 09:39 PM
grclark351's Avatar
grclark351
also, a long stroke engine will produce lots of low end torque and tend to not want to rev extremely high. a short stroke engine will be able to rev higher because of less centrifugal mass, and will need to rev higher than a long stroker to make it's power. think of a regular hand ratchet(short stroke) and a breaker bar (long stroke).
Old Oct 2, 2004 | 08:26 PM
CATdieselpower's Avatar
CATdieselpower
the 351m and 400 have the same block, same heads, same everything EXCEPT for the crankshaft, and pistons. They Have the same bore at 4.00 inches, but the stroke for the 351m is 3.5 inches, and the 400m has a stroke of 4.00 inches, making more torque
Old Oct 4, 2004 | 08:20 PM
Rifleman7.62's Avatar
Rifleman7.62
i'm going to ditto what these guys have said. Long stroke is good for low end torque but does not take the high revs. Shorter stroke engines can give more horsies at higher rpms but you won't produce the low end torque. Your friend does have it backwards
Old Oct 4, 2004 | 10:28 PM
Sanders's Avatar
Sanders
Also, bigger bore means more torque
77_F150_4x4
Nov 19, 2007 10:58 PM
snipAR-15
30
Nov 3, 2007 06:53 PM
STGFordCrazy04
26
Sep 13, 2007 07:57 PM
1974fordtruck
Sep 25, 2002 03:04 AM
