Sponsored by: Real Truck
Drilled threw harness
Old Sep 22, 2004 | 09:59 PM
hgturbot's Avatar
hgturbot
I was drilling threw the rubber grommet to run some lines and took out some wires on a 1TON 2003 super duty diesel. I reconnected every line I damaged and everything functions but doesn't start. I doubled check my lines with a meter and they are all good, no bad fuses, relays and the fuel switch on the pass. kick panel is on. During all this mess I had the battery disconnected so I wouldn't damaged anything else. I was told it's fuel??????? I don't here a fuel pump but I know it's not a chevy?????? Like I said it all works but wont start.. Please help
Thanks
Old Sep 22, 2004 | 10:09 PM
VintageRR's Avatar
VintageRR
If power was still connected I'd be worried about a live short when you drilled through. I've seen computers take a dump just from an arch while getting jump started.
Old Sep 22, 2004 | 10:14 PM
RealMenPowerstroke!'s Avatar
RealMenPowerstroke!
Thanks
Did you check to see if you kicked the emergency fuel shut off switch when you drilled through the wires??
Best of Luck,
Corey
Old Sep 22, 2004 | 10:35 PM
hgturbot's Avatar
hgturbot
Best of Luck,
Corey
Don't know where that is located.
Thanks guys
Old Sep 22, 2004 | 10:38 PM
05-350's Avatar
05-350
Inside cab at right floor board. You should see it marked on the plastic kick panel at your right foot as if you where sitting in the passenger seat.
