Blowing Hot Air
Old Sep 22, 2004 | 08:26 PM
Bob O GomA's Avatar
Bob O GomA
Blowing Hot Air
My airconditioner worked great then I turned it off and in about 5 mins I turned it back on, It would only blow hot air like the heater. Only once has it came back on . I turned it off till i needed it a few mins later but nothing. I have checked all the fuses (that I know of).
Any suggestions???
Old Sep 22, 2004 | 11:47 PM
wayneo's Avatar
wayneo
So you are saying it will cycle on once in awhile and blow cool air, right, well Bob O sounds to me if this is the case your system may be a little low on freon, doesn't have enough in it to keep the compressor cycling, You can remove the plug from the cycling switch and use a jumper to enguage your compressor to assure you that it is working, but I would say it's time for some freon, if the compressor is working, also may wanna have who ever you get to service it check for leaks in the system, A sign of a leak that you can see is where the lines hook together it will be very dirty looking....Good Luck Bob O, hope this helped...
Old Sep 23, 2004 | 01:29 PM
dono's Avatar
dono
Gone but not forgotten.
I saw the thread title "Blowing hot air" and thought this was going to be about politics.
Dono
Old Sep 24, 2004 | 01:45 PM
Bob O GomA's Avatar
Bob O GomA
The clutch doesnot kick in. seems that it is not getting power. I have checked it with a meter and nothing eather on DC or conentnuity.I cna't find any blown fuses
Old Sep 24, 2004 | 09:45 PM
Cocoagriz's Avatar
Cocoagriz
The clutch will not get power if the system is low on freon. The low pressure switch prevents the clutch from engaging when pressure is low.
Old Sep 24, 2004 | 10:02 PM
Bob O GomA's Avatar
Bob O GomA
Thanks my next step will be to have it services
Old Sep 25, 2004 | 10:44 AM
Bob O GomA's Avatar
Bob O GomA
Is there any way that I can check the low presser switch ??
atruscott
Dec 25, 2013 11:25 PM
Frost29
Nov 14, 2012 12:06 AM
Rus01
Aug 6, 2010 09:48 PM
ckeezer
Sep 21, 2008 10:25 PM
Bob O GomA
Sep 23, 2004 07:44 AM
