backfiring 460
Old Sep 22, 2004 | 06:18 PM
djmac's Avatar
djmac
backfiring 460
lately when i kick my truck into passing gear it "pops" in the throttle body and gurgles and in general does not perform like it should. i thought i was running lean so i changed both filters boosted fuel pressure with no result. someone said set your ignition timing to 34 degrees at 3000 rpm and try it and that did no good either. i noticed that even in park if you floor it will pop up the throttle body under a no load condition. where else should i be looking. i have recently replaced the map and o2 and tps on the projection so i dont think these components have failed. in fact i put a voltmeter on the tps and it performs within spec. what do you guys think?
Old Sep 27, 2004 | 07:04 PM
smoke n tires's Avatar
smoke n tires
almost anyback fire is a result of incorrect timing. what year model? other things to check are for vacuum leaks by spraying carb cleaner around intake gasket areas and anywhere a vacuum is applied. the motor should change speed if you have a leak and it sucks in the carb cleaner. does it idle smooth?i would still bet on it being a timing problem. double check all timing components.
Old Sep 27, 2004 | 07:07 PM
smoke n tires
also, did you change exhaust to a open flowing system. lack of back pressure can lean you out causing this. check for a collasped cat, rare but possible
PaysonPSD
96
May 18, 2023 10:17 PM
IcemanV8
Jun 19, 2014 05:55 PM
Superduty.pride
Oct 13, 2011 12:08 PM
llcustom
Modular V10 (6.8l)
Jul 1, 2009 07:59 PM
djdurrett
1997 - 2003 F150
Mar 5, 2002 08:37 PM
