Bronco II Ford Bronco II
rough idle
Old Oct 23, 2002 | 02:24 PM
bronco222's Avatar
bronco222
rough idle
help im stumped on trying to get a smooth idle out of the beast 2.8 in my 84b2,any ideas????????
Old Oct 24, 2002 | 08:20 PM
BART M's Avatar
BART M
rough idle
EGR valve(leak), PCV valve(clogged), insufficient fuel supply, not enough air goin in, vacuum leakage, or internal problem, <--that could be camshaft, or loss of compression(try the head gaskets)thats all i can think of, hold on im gonna look in the haynes manual.
ok air filter,check intake and make sure all bolts are tight, carb out of a adjustment. well thats all i could think of and what the haynes manual said
Old Oct 24, 2002 | 09:04 PM
BART M's Avatar
BART M
rough idle
