Bronco II Ford Bronco II
a rear axle question
Old Nov 30, 2001 | 02:58 PM
josh3972's Avatar
josh3972
Old Sep 27, 2002 | 02:39 PM
89_bronco2's Avatar
89_bronco2
ive been hearing that there is a wire that you can cut to make it 2wheel drive all the time right now i olny spin one anyone know that wire ?????
Old Oct 24, 2002 | 09:04 PM
BART M's Avatar
BART M
i dont know what your askin but im gonna answer and hope to god that i figured it out. your saying that only one wheel is spinning when you are..??????...doin a big pro-fuelly, grabbin gears? right? well if thats it then try putting it in reverse, back up a few feet, and then light em up, if this dont do it then you probably dont have limited slip. you could go find another axel if its really what you want......i can break mine loose and boil both the tires at the drop of the hammer. tehe
