I currently have a K&N replacement filter and want to put the whole system in with the cone filter / throttle body hose.I've seen them for the 4.0 L plus Bart M has one on his BII mods .
So,if I was to do this this install the K&N is there any mods I need
I already have the flowmaster exhaust going and soon to add the jet chip.
no actually everything is just directly bolt on and you can use your factory air hose you just gotta get the filter that has the same Dia. as the ID on the hose. i would suggest getting a TB off of a 87 2.9 while your at it. it does make a difference.
