explorer heater blend door
Old Sep 22, 2004 | 07:32 AM
Harper's Avatar
Harper
Jeff Frank shows a fix for repair of blend door, drilling etc. Any one know how to get to the shaft without removing the plenum? thanks
Old Sep 22, 2004 | 09:51 AM
Opera House Works's Avatar
Opera House Works
Not sure what you are asking. This fix just requires removing the actuator.
There was an AC article about removing the AC unit under the hood and replacing with new door. This requires recharging the system, buying the entire assembly to just get the door, and some cutting on the door to slip it in.
Dropping the glove compartment door alows you to cut the plenum to move the door manually. With small hands, you may be able to remove the door that way. It is very tight and a positive outcome is unlikely. I move the door on mine manually. Just have a summer and winter position. Never felt the need to do anything more. If you cut, there are two seams. Cut above horizontal and to left of vertical. Else you hit the heater. Duct tape seals it up.
Old Sep 23, 2004 | 08:21 AM
ajguzik's Avatar
ajguzik
Check out the 'free blend door fix' at the top of the forum. With a little patience, you can pry the actuator of the top of the plenum. Plenty of pictures and instructions in the link, and it works like a charm. I screwed around with it for a couple of months before I googled explorer heater problems and found this forum and the fix.
Brian Frank
May 24, 2016 06:41 PM
SeaCarr
Apr 21, 2016 10:44 PM
Snooze
Aerostar
Aug 20, 2011 02:57 PM
ajguzik
Oct 16, 2007 03:03 PM
coastie-ford
1997 - 2003 F150
Jan 31, 2007 06:44 PM
